TwinTurbo.NET: Nissan 300ZX forum - The only difference between the blocks is the NA has
na300zx (OH)
on July 23, 2008 at 8:29 AM
The block is different. I think you can drill
posted by 600ZXR
on July 22, 2008 at 09:33 PM
check valves where the oil filter tree bolts up and the TT has plugs (there
are obviously other differences on stuff that bolts up, but I am referring to
the actual block casting and plugs... nothing that bolts on). The actual
casting is identical.
NA to TT engine rebuild
Mikezdad
19:13:24 07/22/08
600ZXR
21:33:07 07/22/08
The blocks are the same, both use oil squirters that unbolt. (n/m)
Fast300
01:41:03 07/23/08
I didn't remember them in my N/A block
600ZXR
02:59:05 07/23/08
The only difference between the blocks is the NA has -
na300zx (OH)
08:29:30 07/23/08
Re: The only difference between the blocks is the NA has
Mikezdad
11:49:57 07/23/08
Oil Squirters: if you're going with aftermarket TT Pistons
ZXers
19:39:34 07/23/08
As I recall the heads are different. I wouldn't wast my $
93 Blue Z32
21:31:25 07/23/08
Re: so any ideas
Mikezdad
06:45:45 07/26/08
